Two sub vi s simaltaneously needs data from a queue
    I have one queue and need to execute the following:
(a)    One vi displays data from the queue by using dequeue function.
(b)    Another vi parallely needs to save this data in a text file from the queue.
These two vi s are called as subvi s.
When (a)  executes,that data will not be available in the queue and so  (b) cannot save that data in a textfile since it is not available in the queue.
Please give the solution
(3,906 Views)
You can enqueue the data again after (a) executes so that it will not be lost.
Im thinking of something like this:
(1) Enqueue data.
(2) Dequeue your data on the vi displaying your data.
(3) Re-enqueue your data on that same display vi.
(4) Dequeue the data on the vi that logs the data
(3,902 Views)
to expand clnglenn's suggestion: You should use a different queue for step 3&4…
Btw. I would do the data saving part first, before displaying the data on the UI.
(3,870 Views)
You can simply put the same data into two queues.
One for display, one for logging.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,866 Views)
I will give you two options.
1. Use a separate queue for each function.
2. Use User Events.  In this case, each subVI would use an Event Structure and register for the User Event.  But both would get all of the data.
Since you are already half way there, I would go with #1.
(3,847 Views)
I suggest using a Channel Writer (Event Messenger type).
(3,828 Views)
Why not save and display the data in one sub-vi?
Without seeing your code it seems silly to add a whole 'nother queue for this.
=== Engineer Ambiguously ===
(3,799 Views)
