Two vectors
Hello everyone
I have a problem with dividing two vectors by matrix.
I have two vectors, I am using math script node to multiply and divide these two vectors. for multiply it is ok and the answer is correct but for division it is not.
I did that with linear algebra module but I had the same problem.
In " math script.vi " I don't know why the "Aal" amount is a DBL while it is a vector and we have to have an array nut a DBL
Would you please help me to find out my error.
(2,286 Views)
Hi Sml,
when you get unexpected results then you should not forget to mention which result you expected!
This is what I get by comparing Mathscript node and linear algebra:
Btw. it also would help when you attach all needed subVIs and control definitions when you attach VIs like "math script"! It also would help to use better names for your VIs: why does the "matrix" VI also contain just a Mathscript node?
(2,280 Views)
Hello GerdW
thank you for your reply.
Please look at attached .vi (it is with out sub vi ).
The formula is this :
The " Aal " answer is not a vector and this is my problem. How can I have a vector answer?
I changed the data type and select 2D array or Matrix but it didn't change
Would you please help me to find my error in this program?
Thank you
(2,223 Views)
(While a 1D array is sometimes called a "vector", nothing says that a 1D array with two elements should represent a vector in the XY (or complex)  plane with the first element representing x and the second y )
You have complex numbers, so do complex math using complex data!!!
(and no, you don't need Mathscript for any of that!)
(2,197 Views)
Not sure why you have that "round to inf" for you "e" variable. But if you don't really need that, you can eliminate a lot of explicit trigonometry because you can form a complex number from r and theta directly.
(if you really need that rounding, you need to form G more explicitly, but can still simplify A and B).
Or even use array operations to reduce duplicate code (and potentially take advantage of e.g. SIMD instructions) same result!.
(2,185 Views)
