Two web-based separate exe
Is this possible to run two executables with enabled web server on this same computer?
I need to use remote access to two separate exe operating on this same computer.
Separate programs works fine, access also, but when there are running together, access is only to first of them.
Do you have any experience?
Any restrictions? Any exceptions?
(3,846 Views)
Accepted by topic author MikrobiUK
Hello MikrobiUK,
Here is a Knowledge base article that should help with your problem : http://digital.ni.com/public.nsf/allkb/7B5D6CC1CBCE32C98625716C00828BF4
Also, on the forum a similar question has been answered http://forums.ni.com/t5/LabVIEW/multiple-remote-front-panels/td-p/2174064.
Hope these will help you.
Kind regards,
Shruti.V
(3,771 Views)
Hi Shruti.v
Yes, that is exactly this solution.
Thank you 🙂
Regards
Mikrobi
(3,760 Views)
I am glad I culd help MikrobiUK.
All the best with your application.
Shruti
(3,758 Views)
