Type-defined Shared Variables on a Real-Time target cause Remote Panel to fail
This is another workaround I have found organizing a large project.  This is supposedly fixed in Labview 2012.
If the type definition file(.ctl) is in the same folder as the shared variable library file(.lvlib), the program executes normally.  If it is moved to a different folder, the executable fails at startup.  I ran across this problem when I was moving files on disk.
FYI, FFO.
Message 11 of 11
(573 Views)
