Type definition force update
Is there a way to force LabVIEW to update all instances of a type definition, that is to reload them from the file?
For example, if I need to change the documentation (description or tip strip) of a type def after it has been created and propagated through my application, this (manually initiated) function would force all instances to be reloaded from the *.CTL file. This is a different function than a strict type definition. For a regular type def, if some components were changed to be hidden or disabled, this 1 operation would allow all instances to be updated at once.
Currently, to propagate non-data-type information you must use a strict type def (incomplete functionality, but encompasses the GUI aspects) or manually reload each instance to propagate changes. My understanding is that the WHOLE PURPOSE of a type definition is to prevent the user from manually keeping multiple instances synchronized.
Thanks for any ideas.
(4,203 Views)
Type definition propagates only properties that affect data only. Strict type def propagates and fixes everything. Documentation is appearance, it does not propagate with non-strict typedef.
I usually open typedef, make GUI changes, change type to strict, apply changes, change back to non-strict, save, close.
(4,158 Views)
