Type error in argument 2 to `LoadPanel'; found 'pointer to char' expected 'int'.
Hola me llamo marco  y estoy comenzando a conocer labwindows 9.0 pero almomento de complilar tengo un error  en elcual no lo se reparar y me gustaria si alguien me puede orientar
cuando quiero compliar queda  en ese punto
t t;
    double ti2;
    double pl2;
    int bbbb;
    double y;
    double pl1resp;
    int jj;
    double tf2;
    int w;
    int r;
    b = 0x3f8;
    OpenComConfig (1, 19200L, 0, 8, 1, 256, 25, b, 0);
    SetCTSMode (1, 0);
    SetComTime (1, 0.1099999994039536);
                        P1 = LoadPanel (0, "panel.uir");
    DisplayPanel (P1);
    ini = 0;
    n = 1;
muchas gracias a quien me pueda ayudar  y de ante mano muchas gracias
(4,068 Views)
Where is the function 'LoadPanel' defined.
I looked through cargas.c and didnt find where it was defined.
What is the pointer? The "0" or the "panel.uir"?
Just put a * in front of the pointer to get the pointer's value rather than simply the pointer itself
Cory K
(4,052 Views)
Post your question to the LabWindows/CVI board. This is the LabVIEW board.
(4,048 Views)
Oh, I thought that was C, I haven't worked with LabWindows before, I didn't realize it was a C based language.
LoadPanel must be a native function in LabWindows.
Cory K
(4,039 Views)
