U16 to ENUM
I have a large text ring constant. I would like to convert it perminantly into an enum constant (not at run time, just for programming with). Anyone have any ideas how I might do this?
Cheers, Alec
Message 1 of 8
(4,244 Views)
Look at the Right Click Framework.
There is one utility to create and Enum from an array of strings.
Message 2 of 8
(4,234 Views)
how would you generate an array os strings from a Text Ring?
Message 3 of 8
(4,232 Views)
Accepted by topic author alecjcook
Cheers, Alec
Provided the strings are not duplicated and the values are consecative then...
pop-up ring and choose make control.
pop-up on control and selecte replace >>> navigate to an enum
Done
Ben
Message 4 of 8
(4,224 Views)
Try the documentation. For a text ring the Strings[] property returns the items as an array.
Message 5 of 8
(4,222 Views)
Create a property node for the text ring control.  There is a property called Strings[] that you can read to give you the array of strings.  Create an indicator wired to that and run your VI once.  Now you have an array of strings indicator.  Change that to a constant then use the right click tool on that to Create the enum.
Message 6 of 8
(4,220 Views)
create a property node for the ring object and select the property "StringsAndValues[]", this will get you an array with a cluster element with the data your after.   you'll then have to use a for loop and extract the elements you need.
Message 7 of 8
(4,205 Views)
Message 8 of 8
(4,184 Views)
