U32 ? I32
Why "LV" uses "I32" instead of "U32" ... whereas the result is never negative?
for example:
- the output "offset past number" of the function "Decimal String To Number"
- the loop iteration terminal of a While Loop or a For Loop ...
- the output "size" of the array size function
What is the meaning of a 32bit signed integer for a result which will never be negative?
Why did the labview developers make this choice?
(8,820 Views)
It take universal result into consideration. You can take positive value only in U32 but in I32 both values can be stored
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(8,810 Views)
"with a I32 both values can be stored" ... indeed, good point!
but I think this "universal choice" causes a lot of unnecessary coercion dots!
What do you think about it?
(8,796 Views)
Accepted by topic author ouadji
I guess it is to make it consistent and thus to have less coercion dots. E.g. the output of search 1D array must be I32 since it returns a negative value if there's no match. If you wire a -1 to an index array you get the default value of the array data type.
The same is true for many other places where negative (-1) has a similar meaning. So there would be lots of coercion dots if LabVIEW would use U32 where a value can be only positive (like array size) but I32 where it can be both positive and negative.
(8,787 Views)
Universal choice i.e. for both negative and positve value. Some function generates + result and some - result. Hence we need some indicator which take both the values. So I32 is best
--Ranjeet
(8,770 Views)
