U32 RGB and 24-bit pixmap
Hi
i work with movie and i need to analyse frame by frame, so i save the frame like .bmp, theese pictures are U32.
When i analyse the pictures, the function "Unflatten pixmap" has 1-bit, 4-bit, 8-bit, 24-bit.
I would like know if the 24-bit is the same to U32 RGB.
Thank you for yor help
Tonio
(3,396 Views)
Yes, if you look inside the Unflatten VI you can see that it removes the transparency byte from 32 bit images and treats them as 24 bit images.
___________________
Try to take over the world!
(3,391 Views)
Thak you so much for the immediate answer!
(3,376 Views)
