UART to DAQ
Accepted by topic author NahidIIUM
The link does not work.
With a USB connection, if it creates a virtual serial port, then you can use LabVIEW with it. You still need to get the command set/programming manual of the driver in order to communicate properly.
Message 11 of 21
(2,506 Views)
Hey Dennis, really appreciate the help. I think you've explained it clearly. Just to be on the safe side, I'm attaching links to the converter and the driver in order to make sure I have the necessary material to continue with my project.
The converter : http://tutorial.cytron.com.my/2012/05/16/uc00a-usb-to-uart-converter/
the driver: http://tutorial.cytron.com.my/2012/05/29/sd02b-stepper-driver-features-uart-interface/
Message 12 of 21
(2,439 Views)
Hey Dennis, your answer is pretty clear. Thanks alot. But just to be on the safe side, could you please check these links out and confirm that I have the necessary and right material to continue on with my project?
Message 13 of 21
(2,439 Views)
Hey Dennis, your answer is pretty clear..thanks alot ! could you please check out these links and confirm that I have the correct material to continue on with my project. With regards to the programming manual, yes, I do have that manual to use the driver and the motor. What I am more concerned about is this USB - UART converter.
Message 14 of 21
(2,439 Views)
Could you please check these links out and confirm if I have the right material to continue on with my project?
Message 15 of 21
(2,442 Views)
Hey thanks Dennis, really appreciate it.
Well these are two links describing the driver and converter in short and in detail. Please check them out and let me know if I have the right material to continue with my project?
Message 16 of 21
(2,439 Views)
Yes, I have the manual to the driver that describes how to use it. So from what I read about the converter, it basicaly becomes a COM Port to the laptop. So I won't face any issues right? And again, I use VISA to communicate with the converter (COM Port) or is it some other way?
Message 17 of 21
(2,480 Views)
The only supported api for serial communication is VISA. I won't make any comment on your converter since you have not provided a link or its manual.
Message 18 of 21
(2,475 Views)
Okay, here is some material related to the converter as I can't seem to attach links here..
Message 19 of 21
(2,463 Views)
It uses an ftdi chip for the serial emulation. This is pretty common. I've used used numerous converters with this and I've not had any problems.
Message 20 of 21
(2,454 Views)
