UDP Data format
I am using a cRIO 9031 to collect UDP data and save it to a file. Is there a way to save the raw UDP data anything other than string form? For example the first line of the UDP data is
SCN1 0400 0000 8E0D 4904
But when i save the data using Write Binary or Text file, it saves is as
SCN1   ŠUQ~
I would like to preserve the original form of "SCN1 0400 0000 8E0D 4904".
Any ideas what I am doing wrong here??
(4,233 Views)
Accepted by topic author rcee
This is hex-string. You can transform string to numbers and then numbers to hex-string
(4,184 Views)
Thanks for the quick response. It worked.
(4,172 Views)
That innocent looking red dot on Number to Hex String is your data being exploded into a U64 array before conversion.  If you are doing this operation many times or on long strings you should wrap that primitive in a For Loop.  The scalar version does not coerce the input to U64 so it is faster.  One of the very few instances where a loop + function in G is faster than passing an array directly to a function.  Seeing that this is still happening in LV15 probably means I should give up hope of it being fixed.
(4,157 Views)
