UDP ERROR 113
DEAR READERS
                                   I AM A BEGINNER LEVEL LABVIEW APPLICATION ENGINEER. I AM TRYING TO COMMUNICATE TWO SYSTEMS(MY LAPTOP AND COMPUTER) USING UDP PROTOCOL IN LABVIEW.  I HAVE CODED THE REQUIRED IN BOTH THE SYSTEM. I AM FACING ERROR WHEN I RUN BOTH THE SYSTEM SIMULTANEOUSLY.
                                    THE ERROR NUMBER IS 113 AND 56 SOMETIMES.
ERROR 113 SAYS THAT THE MESSAGE SENT ON A DATAGRAM SOCKET WAS LARGER THAN THE INTERNAL MESSAGE BUFFER OR SOME OTHER NETWORK LIMIT OR THE BUFFER USED TO RECEIVE A DATAGRAM WAS SMALLER THAN THE DATAGRAM ITSELF.
         WHAT SHOULD I DO TO REMOVE THESE ERROR 56 AND ERROR 113???
(5,367 Views)
First, fix your keyboard. All caps is considered shouting and not appropriate behavior.
Second, attach your code.
(5,365 Views)
Dear Reader,
I regret for the caps letter.  I am sending you my code UDP try and udp try receive. I am facing 113 error.You can run it simultaneously in two system and see to yourself. I am a beginner in LabVIEW. I am happy to get your help.
(5,337 Views)
Hi Srifour4,
Just check with the attached VI, that I have modified to resolve your problem.
I have come up with your attached VI "udp try.vi". The way you programmed that vi is not at all a good way of programming. Just go through with this basics. Specifically learn about the data flow and then start realising your ideas.
All the best !
Vijay
(5,311 Views)
