UDP Write affecting decimate1D array
I am doing parallel UDP read-write for my application. First of all, i am collecting the data through UDP read in an array then segregating it through decimate 1D array.
Now every time I try to write the data (basically overwriting the analog value) it successfully write the data but gives me 0 (Zero) for that period I hold the write button and also changed the sequence in decimate 1D array.
Please see the attached image for better understanding.
Thanks in advance
Suyash
(3,334 Views)
The problem is most likely on the diagram, so why don't you show us that instead? Best would be to attach the actual VI.
(I suspect a race condition or other coding mistake)
(3,303 Views)
So your code has a bug, and instead of showing us the code (so we can help you find the bug), you show us "proof that there's a bug".  We believe you.  Now show us the code (by attaching the VI -- don't attach a picture of the VI).
Bob Schor
(3,264 Views)
