UDP in RT
I've been running LV Real Time with out any probelm.  Last night, I added a loop to monitor a port using UDP and return a response on request.  This crashed the machine.  Should I be surprised?  Did the RT UDP request interfer with the normal running of the code?  Thoughts, please.  Thanks.
(2,728 Views)
I would try using the LabVIEW built-in UDP examples to test the communication. UDP should not cause your RT controller to crash, but it would depend on what your code is doing.
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
(2,707 Views)
