UFF-Export
I am trying to export a power spectrum and, later on, a coherence-signal into an uff-file as you can see in my VI mentioned below. Afterwards I try to load the signal from my created uff-file into a DataViewer like in the "Sound and Vibration Assistant". Unfortunately my measured signal, before converting it into universal file format, and my loaded signal in the DataViewer are not the same. Viewing my uff-file with an editor suggests in my opinion that there must be a failure while creating the uff-file.
Is my assumption correct or is there a failure in the construction of my VI? How can I find a remedy for this problem?
Thanking you in anticipation.
(3,390 Views)
Hi IKAFKA,
I have run a basic test with your VI and opened the resulting UFF58 file in DIAdem and the S&V Assistant. All three graphs (including the LabVIEW one) showed identical results (except for the frequency range which can be adjusted).
What discrepancies did you find in the file views? Could you provide us with a screenshot of the issue or a sample file?
Thanks and best regards,
Peter
Peter A.
Field Sales Engineer, NI Germany
(3,352 Views)
Hi PaSB,
my issue has been settled.
Thank you for your immediate reply.
(3,326 Views)
