UI Automation Peers Configuration
I am working on a Customer project that is using LabView with regards to UI Automation.
I'd appreciate some help around the question - is LabView configurable to enable UI Automation peers that can be consumed by .NET frameworks like Microsoft UIAutomation and similar?
After some research in the forums here I could not find a definitive answer (apart from using the NI proprietary automation solution, which is a no go for me).
Thanks in advance!
Message 1 of 1
(940 Views)
