[UI] How to display symbol in multicolumn's header ?
I've modded my UI to switch from a Table to a Multicolumn 'system'
widget in order to gain some other features and methods :
Yet there is a problem...
I wantedto show a symbol in the columns' header to display the sort
order selected. I wrote a little algo that works quite well and expected
to display an arrow in the header :
I found this but it doesn't help like I expected :
https://lavag.org/topic/7002-multiple-glyphs-columns/page-2
Any info about how to do this ?
David Koch
(3,155 Views)
Hi David,
ItemSymbols apply to table items or "objects". You can have symbols in the table content, but not for the header line…
What is a "widget"?
(3,133 Views)
@GerdW : OK, another limitation... I modified my algo this way :
Hence I just add '<' or '>' after the column's name to indicate the sorting order.
Widget : graphic command of a value (tab, edit, button, radio, ...)
David Koch
(3,122 Views)
Hi David,
widget aka FP element aka control / indicator?
(3,120 Views)
Yeah, that's right :
http://en.wikipedia.org/wiki/Widget
https://www.wxwidgets.org/
David Koch
(3,116 Views)
