UI with grayed out options until user enters required data
I suspect that what you are meaning is that you have some controls and/or indicators that are not needed for some selected test. In that case you can hide those controls/indicators. If they are in the sequence of controls that you want to enable then you will need to have code to select the next control in the sequence.
Message 11 of 11
(370 Views)
