UNABLE TO START NI-OPC SERVER
WHEN START OPC SERVER
Error in NI-OPC:  Unable to load driver dll 'c:\Program Files\National Instruments\Shared\ NI O...
PLS HELP..........
(3,507 Views)
see here and post back if you still have problems.
(3,505 Views)
I USED BOTH COMMANDS
NET STOP
NET START
THEN ALSO AM GETTING SAME PROBLEM
(3,502 Views)
I TRYED BOTH COMMANDS
STILL AM GETTING PROBLEM
(3,497 Views)
Do this as a quick attempt. Under the  "OPC Settings" tab there is an option for "Use DCOM configuration utility to set security" ... this is ON by default. Uncheck this box and restart the service.
see this solved thread for more details. Don't hesitate to post back if you still have problems. We are glad to help you.
Mathan
(3,496 Views)
I DID, WHAT U SAID ABOVE POST
BUT I STILL AM FACHING PROBLEM......
THIS IS TIME TO LEAVE OFFICE , I LL BE BACK TOMORROW
BYE MADHAN
(3,490 Views)
