URG-04lx USB driver problem
Hello sorry if the topic is seems a bit not related, but later i will need to connect to Labview, so this step is really essential to me.
First of all,i want to ask did anyone use the Hokuyo urg-04lx laser range finder? The case is that the company is giving me the download link for the usb driver installation, however it was came out as .inf file, so i cant install or register to the computer. http://www.hokuyo-aut.jp/02sensor/07scanner/download/index.html
Another matter is that the Hokuyo urg-04lx i was intended to connect are not detected by laptop at the very instance, for giving example, the USB keyboard and USB mouse will be able to install driver for itself and later the computer will allow to communicate with them. However in this case the Urg-04lx is not giving any synpton as above. I was advice that i should install the USB driver for the Hokuyo urg-04lx first before i continue for the USB connection, however i was unable to install as i stated above.
I wish for anyone who could help me or any advice regarding this product. I am current using window 7 64 bit. Any advice is much appreciated, and if the topic is not related please notify me so i will shift to the recommended category.
Really thank you!!! 😃
(3,323 Views)
Your problem isn't related to any NI hardware or software. If you have a problem installing the inf file, then you really need to contact the vendor with details on what happens when you attempt the install. The readme says the inf file is compatible with windows 7 so you need to be a bit more specific about your comment about 'cant install or register to the computer'. Pretty pointless for anyone here to try to duplicate the problem unless they have the same device.
(3,320 Views)
