[URGENT] Help with write to a Spreadsheet VI
Spoiler
Hi Everyone,
I am working on a  VI to write the data which I receive  from a Eurotherm Temperature Controller.
For now I have used a Simulate Signal express VI to  simulate the Eurotherm in my VI and it woks kinda fine.
There are a couple of things  I do not understand.
First, whenever I run this VI I get two columns in my spreadsheet. One having the necessary data and the other a column of 0's about which I have no clue.
Additionally, I would also like the timestamp to this spreadsheet. I have been reading some stuff from this forum and a lot of people have done things which seem quite complicated.  Is there an easier way to get the time stamp in the spreadsheet
I couldn't use the the EXpress VI for this task as I have to save the file in a new location everytime and having a new name.
Suggestions and ideas are most welcome. I have attached the VI with this post
Hope to hear from you guys soon as always.
Kind Regards,
Jalashwa
(3,233 Views)
1. You probably want to use a Chart instead of a Graph.  A chart includes a history instead of just the last capture.
2. Since you want time information, change the From DDT to output a single Waveform.  There is a function called Export Waveform To Spreadsheet File.  Use that.
(3,226 Views)
Hey Crossrulz,
Thanks for getting back to me.
I tried implementing what you had advised me to.
There are somethings I can't change in the VI.
I was hoping if you could help me with that.
I just want the time stamp for which the experiment runs in seconds/ min . I do not need the date and the actual time of the experiment. I was referring to  a White Paper by NI, http://digital.ni.com/public.nsf/allkb/BE8023E1925F476E86256F4A006FB0D9
with the hope of completely removing the date and the default time in the SubVI but to no avail.
I have attached my VI in this post along with a sample .xls that I generated. Even the second column in my VI doesn't make much sense to me.
Looking forward to your kind inputs and help.
Jalashwa
(3,148 Views)
Hey,
I did something else .
Could you please have a look at this post
https://forums.ni.com/t5/LabVIEW/Help-with-File-Dialog-Express-VI-while-saving-an-Excel-File/td-p/36...
BR,
Jalashwa
(3,140 Views)
Hi Jalashwa,
Please see the attached VI, hopefully this will help.
There are notes on the block diagram about what the VI is doing. I typically do not use Express VI's, unless if it is necessary, I prefer to build my time\data arrays manually so I can make them exactly as I like them to be (or as the project requires).
Please respond with any questions.
Thanks.
Mike
Certified LabVIEW Architect
Miami University
Instrumentation Laboratory
CLA Logo
(2,890 Views)
