US Digital QSB-S resets when disconnected
Hello everyone,
I am adding the QSB-S functionality to a bigger data acquisition program that was created using labview. The code for the QSB-S works fine when connected to the VI (please see the attached VI), the problem is that if the QSB-S gets disconnected and connected again it will reset the counts to zero, I guess that's the default option, but I need the program to keep the last value read by the QSB-S if it gets disconnected and continue the reading from there when it is connected again. Is this possible? any ideas?
I hope you can help me.
Luis
(1,489 Views)
Hi Luis,
Are you talking about those devices? Well they are bus-powered, so disconnecting and plugging-in again will surely reset them…
You need to detect in your software when that devices gets disconnected: you should receive some errors messages then.
When such an error occurs you just store the last reading in a shift register. When the devices gets connected again and restart to count from zero you just add the stored value to the current readings…
(1,453 Views)
Did you get an error when you build your program and ran the executable?
Error 4 occurred at Read from Binary File
Possible reason(s):
LabVIEW: End of file encountered.
(1,216 Views)
Hi. I now its been long but do you still have the "Counter Math QSB-S subvi"?
(640 Views)
