USB 2009 2 channel daq mx osciloscope
I have an issue with a osciloscope project.
Does someone have a more easy example to help me?
I already have some from other websites like "studentscope" "labviewscope" etc.
I realy could use a more simple one. But with daq mx tools. No  DAq assistant.
Thank you
(2,229 Views)
Hi number,
What is this "issue"?
Did you examine all those example VIs, coming with LabVIEW and DAQmx?
All those DAQmx example VIs only use plain DAQmx functions…
You really should use AutoCleanup from time to time. And reevaluate your algorithms (aka refactoring):
(2,191 Views)
