USB-4431 Not Being Found by Measurement & Automation Explorer
I have run into an issue on a machine running LabVIEW 8.5.  When I plug my USB-4431 in it is not found in Measurement & Automation Explorer.  I have install DAQmx 9.3.5 (the version that came with the device).  Is that maybe my problem that LabVIEW 8.5 and DAQmx 9.3.5 aren't compatible.  Any help you can give would be great.
P.S.  I have tried the device on a computer with LabVIEW 2011 and DAQmx 9.3 and it seems to run fine.
(2,368 Views)
