USB 5V trigger
how can i switch 5V on/off of an USB link ? With VISA ? Or will i have to use an Digital I/O?
(4,083 Views)
I don't understand what you are trying to do.  Are you looking for a signal like a TTL out (i.e. either 0 or +5V, but not requiring much current)?  If so, you can use something like the NI USB-6009, which has a multi-line Digital I/O port.  Do you need to drive something (like a relay) that needs 5V, but some current?  You might need additional circuitry, largely to provide the current (and maybe an external power supply).
Bob Schor
(4,080 Views)
Good day,
Your answer lies in my expectations.
What we are trying to do is within a testsystem, letting labVIEW manipulate an USB connection (alive or not), to access a mass storage device (as test), so that no manual plug out/in is necessary
regards,
Koen.
(4,070 Views)
In that case, I'd design a simple circuit that has a TTL in and functions as your Connect/Disconnect, with its own low-voltage Power Supply (perhaps sharing it with a USB Hub).  You can then drive it with a Digital Out line from something like a USB-6009 (but don't plug this into your "USB Disconnector", of course!
BS
(4,050 Views)
