01-29-2021 05:20 AM
I am using a USB 6001 to try control an actuator, the actuator I am using is the 50mm stroke option in below link:
https://s3.amazonaws.com/actuonix/Actuonix+L12+Datasheet.pdf
It requires 6V power and 0-5V for control. I am using SPD3303X-E programmable power supply to provide the power supply for the actuator. Therefore, I am just using the USB 6001 to send a voltage to the actuator for control.
However, I am unable to get the actuator to move at all. Occasionally, the motor will whirl but no movement, which seems like a lack of current issue, but that doesn't make sense to me as it already has power from the power supply. Please see images below for setup. I have used a multi-meter and can confirm a voltage is being output.
Additionally, I am able to get the actuator to work if I provide the 0-5V via a second channel on the power supply, please see image below.
I am really confused regarding what the issue is. Does anyone have any ideas about what it could be.
If anyone can help it would be really appreciated.
Kind regards,
Robert
01-29-2021 12:48 PM
