USB 6003 and thorlabs scanning galvo system
Hi all,
I purchased the USB 6003 DAQ card for operating thorlabs' scanning glavo (GVS012).
But, when I apply the analog output voltage signals to the driver board, it doesn't work, the current was zero on the power supply.
I was wondering if the DAQ card is proper to operate the system. The required spec is as follows.
- Dual bipolar -10 to10V DAC analog output channel(differential),
- DAC clocking frequency higher than 20kS/S, higher sampling frequencies like 100kS/s are recommended.
Thanks in advance,
Message 1 of 8
(4,641 Views)
Compare it to the specs!
The USB-6003 is only capable of 5000 samples/second per channel.  And is not differential analog output.
Message 2 of 8
(4,626 Views)
Hi minjcha,
Does the USB-6003 output the expected voltage on its AO pins? Did you verify using a DMM?
The USB-6003 can output ±10V on its both AO channels.
It only offers 5kHz samplerate, simultanously: why do you think you need more than this?
Even though ThorLabs asks for "differential analog input" it shows schematics with -Input connected to Ground pins (see page 14 of the manual!), so the output of the USB-6003 should be ok.
I guess you also wired the ExternalEnable input of your device?
Message 3 of 8
(4,610 Views)
Hi GerdW,
--> Yes, I connected AO pins to the servo driver board. Also, I connected my - input to AO Ground.
But, What is the External Enable input? Should I connect this to my DAQ?
Message 4 of 8
(4,594 Views)
Accepted by topic author minjcha
Hi minjcha,
And did you verify the correct voltage using a DMM or similar?
The ExternalEnable is (probably) explained in the manual to your servo driver. (Atleast it should…)
Most motor drivers I used so far need some "Enable" signal to actually power the motor. This is used as (simple) safety feature. Most often that Enable is a simple boolean signal…
Message 5 of 8
(4,591 Views)
Hi GerdW,
I have tested the voltage using DMM and it gives the correct voltage that I coded. Also, I enabled the driver board but didn't work..
Do you have any idea on how the analog voltage signal looks like? I am currently generating the analog output voltage like this (-10 to 10V, increment by 1 V, pausing 1sec in between). -10 V, pause 1sec, -9V, pause 1sec, -8V, pause 1sec,..........0V, pause 1sec,......... 10V pause 1sec.
Minjeong
Message 6 of 8
(4,583 Views)
Hi minjcha,
What does the manufacturer of your servo driver say about this problem?
How should I know? I don't have access to your setup…
Yu should know the answer from your own experiment: I expect some voltage steps as described by you!
Message 7 of 8
(4,570 Views)
Thanks!
I was able to run the system. The problem was the power supply.
Thank you for your help.
Message 8 of 8
(4,553 Views)
