01-21-2013 10:52 AM
Good morning,
I am having trouble finding an NI product that fits exactly same specifications as USB-6008 Multifunction DAQ:
8 inputs
2 outputs
10 kS/s or better
has 16-bit analog inputs and outputs, not the 12- or 14-bit.
Any help is appreciated,
M
01-21-2013
11:15 AM
- last edited on
04-15-2024
01:19 PM
by
Content Cleaner
01-21-2013 11:19 AM
I currently use the USB-6211, just looking for smaller models with same specs as I do not require 32 ports.
Thank you for your reply,
M
01-22-2013
10:17 AM
- last edited on
04-15-2024
01:19 PM
by
Content Cleaner
Hi Mykolaz,
I would recommend going to the USB-6211 page and clicking the "Call Me Now" link so that a sales engineer can advise you about the most suitable product.
Dennis is correct in stating that the simplest product we have that meets the specifications you are requesting is the USB-6211. As you can see in this product search, our USB Multifunction DAQ product line includes the 6008, 6009, and then the 6211. We do not offer any models with 16-bit resolution and less channels in the USB form factor.
Also, to clarify, the USB-6211 has 16 analog input ports, not 32. If you wire using a differential configuration, this is reduced to 8 analog inputs. There are 2 analog output ports and 4 DIO ports.
Best,
