USB 6009 DAQ-Error: -200361 "Buffer overflow in device memory"
Got a Error-Message like in subject only on my new Laptop with USB+ Windows 7 64Bit and LabView 2011. On other PCs it is running without error. Greetings Armin Krüger
(3,760 Views)
What sampling rate are you using. What about samples read, acquisition mode etc. Post your code or elaborate more discussion.
(3,758 Views)
May be read this description here http://digital.ni.com/public.nsf/allkb/611475F9BE62881E86256FDC0062B1BB and get rid of that error.
(3,752 Views)
I am having the same problem...device usb-6009 works fine on XP but executable can only run once on Win7 before error appears. New computer, no other programs running, collecting at 100Hz, 1 channel. Have re done program with LabVIEW 2011, upgraded to latest NiDaq, same problem.
Comments appreciated.
(3,675 Views)
Having similar issues here. We're you able to resolve them? If so how?
(3,622 Views)
My question was answered by John P in a different thread....sucessfully, I might add...
http://forums.ni.com/t5/Multifunction-DAQ/Getting-Error-200361-after-start-stop-of-the-data-acquisit...
(3,614 Views)
