USB - 6009 DAQ queries
Hi all,
Firstly apologies if this question has been answered/posted before and also apologies if it seems rather trivial.
I’m an amateur at things like this!
Anyway I'm using Labview 7 express and USB - 6009.
I quite simply want to record and view a voltage signal and a current signal.
  • I have managed to get the recording into a file sorted. Although the slowest I can seem to get it to record is approx 1 per second, any ideas on how I can get the signals logged at say once per minute?
  • On my front panel the graphical display I have for both signals refused to display the line graph and I have toggled every switch and restarted etc but for some reason but signals will change but the graph will not move along the time axis.
  • on the front panel I want to display both of my channels inputs i.e. voltage and current in a numerical display but at this moment in time when I click create and numerical display I can only view the voltage...any suggestions on how to get 2 numerical displays of separate tings from the one DAQ.
Thanks for all your help and hopefully I've made myself clear in what I want to find out.
Andrew
(2,755 Views)
Hi Andrew
Do you want to post your code on this thread and that way I can see what kind of setup you are dealing with, what you would liek to do seems straight-forward so should work.
Kindest Regards
YatinM
(2,719 Views)
Hi all,
Firstly apologies if this question has been posted before and also apologies if it seems rather trivial.
I’m an amateur also at things like this!
Anyway I want to use Labview 7 express with USB - 6009 / USB 6210.
i have LV 7 Express along with MAX 3.5 , where as i m using NI PCI  XXXX with this software configeration n providing solutions to different end use there fore not able to change the plateform. i recentely got the USB 6009 ( qty = 2 ) and USB 6210 ( qty = 1 ) along with the drivers CDs but these drivers r for LV 7.1 or above version.Thus plz help me by providing the right drivers for the LV 7 express with MAX 3.5
(2,656 Views)
