USB 6009 DAQmx Deployment
Hi.
   I have created a 4 channel differential data logging scope with a NI USB-6009. I would like to deploy this 'easily' to many of my colegues. I have app builder and the ability to build apps, but I would like to include the correct drivers for the 6009 in with the installer (although I have selected NI_DAQmx Core Runtime and NI_DAQmx MAX config support).
   For the running of the app, I have created a Task that consists of 4 channels. I would like it for my end user not to have to configure this. Does anyone know how I might acheive this? My experience of deployment is limited.
Many thanks, Alec
(2,876 Views)
You've selected the DAQmx Core and MAX. The only other thing you should need is to export your hardware configuration so that it can be imported on the new pc. You can go into your local version of MAX and export it there. When you build the installer, you also have an export option.
(2,849 Views)
Hi Alec,
It's also worth installing DAQmx MAX Configuration Support from the install builder if you still want to be able to modify the tasks from MAX as well.
Best Regards,
Chris
National Instruments - Tech Support
(2,817 Views)
