USB-6009 Daqmx Base 3.3 Cannot creat 2 or more channels on Windows mobile 6
I have USB-6009, PDA iPAQ 214, WM6, Daqmx base 3.3, Labview 2009. In order to create new mobile project I use wizard and standart dynamic example: Cont Acq&Graph Voltage-Int Clk.vi. All works ok, but if I add more chanels in VI "Create Channels" or place new VI block and enter "Dev1/ai1", exe on my PDA cannot work correctly. Exception after RUN. I have no idea how build correct application with 3 channels without this exeption...  On PC all works. Whay right way to create channels? I attach VI which don't work, for examle. I read daqmxbase cannot support WM6, but 1 channel work ideal!
Message 1 of 9
(5,423 Views)
Vital000,
Hello and thanks for using the NI Discussion Forums!
Can you post the following?:
  1. Your actual VI (instead of a screenshot)
  2. Screenshot of the exception your seeing (and any other error messages.
Thanks!
Ben Sisney
FlexRIO V&V Engineer
Message 2 of 9
(5,390 Views)
Vital000,
I forgot to mention that, yes, Windows Mobile 6 is not supported along side of DAQmx Base. That means you might be able to get some  of the same functionality(limited) that you would with Windows Mobile 5, but most likely not 100% functionality. This could explain why 1 channel works and multiple channels do not. I will try and help you out, but as this is not supported my ability to help is limited.
Ben Sisney
Message 3 of 9
(5,386 Views)
Hello, Ben S!
Thanks for fast answer! I attach more files about exeption. This files is copy from temp windows directory and actual VI from Labview project.
Thanks!
Message 4 of 9
(5,363 Views)
Vital000,
Thanks for the files. I have a WM5 device (as WM6 is not supported) connected to a USB-6009 and will try to use your code to read from it.  If I am able too, then we'll know that the answer is that the reason it's not working is due to the WM6, however, if it doesn't work then we'll know somthing is wrong with the code somehow.
Ben Sisney
Message 5 of 9
(5,353 Views)
Dear Ben S,
Thanks for help! When will Daqmx base support WM6? The HP support team sad that my PDA can't downgrade to WM5.
Thanks and Happy new year!
Vitaliy.
Message 6 of 9
(5,337 Views)
Vital000,
Sorry, but I do not know when or if WM6 will be supported with DAQmx Base.
Ben Sisney
Message 7 of 9
(5,312 Views)
Ben
Were you able to verify his code on WM 5.0 and eliminating the code as the issue?  I know WM 6.1 is not supported but has anyone verified if it is compatible with DAQmx Base 3.3?
I am able to run applications on WM 6.0 but as soon as I attempt Data Acquistion using a USB 6008 I get an "Incompatible Firmware" error message.  I have updated the firmware on my 6008 and changed the drivers per the Knowledge bases.
TJ
Message 8 of 9
(5,243 Views)
krummelt1,
Thanks for asking. I was able to confirm that the incompatability of WM6 and DAQmx base is the source of these issues.
Ben Sisney
Message 9 of 9
(5,234 Views)
