USB 6009
Hi,i have a USB 6009 DAQ.However i have no idea how to use it together with labview and how to connect the wires.i need to connect to inverter and motor.This is the motor and inverter im using..can you help me??
http://www.orientalmotor.com.sg/products/ac/list/detail/?brand_tbl_code=AC&product_name=5IK40GN-SW2L (motor)
http://www.orientalmotor.com/products/pdfs/2009-2010/B/usa_sc_fe100_200.pdf (inverter)
Message 1 of 12
(4,697 Views)
Have you read the manual: https://www.ni.com/docs/en-US/bundle/usb-6008-6009-feature/page/introduction.html ?
The analog output of the 6009 is 0-5VDC, max 5mA. Your inverter expects a 0-10VDC speed control input...
Jarle Ekanger, MSc, PhD, CLD
Flow Design Bureau AS
- "The resistance of wires in LabVIEW is not dependent on their length."
Message 2 of 12
(4,689 Views)
is there anything i can do?
Message 3 of 12
(4,677 Views)
Run your motor up to half speed? Smiley Wink
Message 4 of 12
(4,674 Views)
Lots of things:
  • Get a different DAQ card
  • Get a different inverter
  • Get a programmable power supply whose output covers the range of the inverter, and is programmed via a 0-5V signal
  • Create a 2x amplifier to sit between the DAQ card and the inverter
  • Use it as is, and run the motor at half-speed
Message 5 of 12
(4,673 Views)
After running my motor at half of the speed,how am i going to connect up the wiring together?
Best regards
Message 6 of 12
(4,642 Views)
Best regards
That question is beyond the scope of this forum. You'd need to look at the manual for the inverter to see how to connect the signal inputs to it. If you are not comfortable or knowledgeable in this area, I would suggest finding someone who can help you.
Message 7 of 12
(4,635 Views)
Thanks. But firsly,my DAQ cannt be reconigzed by my laptop,so i cant test whether my USB 6009 is it working well anot.When i plug in my usb it doesnt show me anything that allow m to know that new hardware is installed.i cant see my device on the "devices and interfaces" in measurement & automation explorer.can help?
Message 8 of 12
(4,614 Views)
Did you install DAQmx? Be sure to get the latest version that works with your specific version of LabVIEW: https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Message 9 of 12
(4,596 Views)
im using labview 2011 and USB 6009 for windows7..which version should I download in order to detect the USB 6009?? thanks
Message 10 of 12
(4,586 Views)
