USB-6210: Differential input pairings - error
I have been having a problem reading differential inputs. For my particular DAQ model USB-6210, the differential inputs are AI0:AI8, AI1:AI9, etc. I have been unable to use those to inputs for my block diagram as I keep getting the Error -200077 (Requested value is not a supported value for this property.... - this error is for AI8, 9, etc, i.e. the other end of the differential input pairing). Please find the attached VI. The RSE readings work fine.
Thank you!
traindoor
(3,134 Views)
Once a channel is configured as Diff, you can not aceess the other input. DAQ knows which pair of cahnnels get paired together.
Just change the I/O spec to daq/Ai0-3 and adjust your indexing into the array.
Ben
(3,123 Views)
