USB-6251 Input channel displaying incorrect waveform
It does work, but this doesn't tell me a whole lot.  By removing the whole Analog Output sections, I have to sample a wave from the function generator.  However, as I tested and said in the original post, everything seems to be working fine when I sample the function generator.  The second element channel only seems to respond strangely when it's sampling the output generated by the board.
Message 11 of 17
(827 Views)
Well, what it tells me is that there is nothing wrong with the analog input. I would suggest you look again at how you are generating the analog output and maybe use a scope to view the signal.
Message 12 of 17
(823 Views)
I've already viewed the output on a scope, and it looks exactly like how I want it to.  And it also looks exactly how I want it to on the analog output waveform, and on the 1st, 3rd, and 4th input waveforms.  Regarding how I'm generating it, the waveform is still being generated when I tested everything with the function generator, so I don't think the code for that is faulty either.
Message 13 of 17
(820 Views)
You've verified how the signal looks coming out of the DAQ card or you've verified how the signal comes out of whatever you are measuring? I would assume they are two different things.
Message 14 of 17
(816 Views)
jchsu wrote:
However, this problem isn't specific to channel 2, it's specific to the second element of the array I created.  If I switched the order of the array so that channel 1 is the second element and channel 2 is the first element, then channel 2 is fine and channel 1 shows the same properties of the error discussed earlier.   All 4 output waveforms are coded exactly the same way.
Does anyone have any clues or ideas what could possibly be the problem?
Jeremy
Message Edited by jchsu on 06-12-2009 04:26 PM
OOFDA! I spent a bit of time on this. Luckilly, I remembered the first rule of the technician- assume some assumption is incorrect.
When you change the order of your array of channels it has no effect on the output array order.  The output order remains AI(1,2,3,4) .  There is no scale that could be applied that is frequency sensitve so, you have a capacitor in parralel with the AI2 input!  This may be a broken ground (since you are RSE coupled) or it may indicate a broken DAQ.  the 6501 has 8 AI, try moving your signal to another available AI and test your cabling.
Message 15 of 17
(810 Views)
Thanks, but unfortunately, I have already tried this.  Any aI does not work when it is the second element of the array (or list).
Message Edited by jchsu on 06-15-2009 01:48 PM
Message 16 of 17
(806 Views)
Another thing I just found out is that the problem only seems to happen when I'm sampling between ~347kHz to ~351kHz.  I am unsure of any other frequency ranges that could reproduce the problem though.  I could probably just get away with not sampling at those rates, but it really bothers me that it's still incorrect at those rates.
Message 17 of 17
(801 Views)
