USB 6259 DAQ express rate of digital output issue
         I have a fairly basic question.  I'm using the USB 6259 NI DAQ, and I'm tried to use both the digital and analog output options on the DAQ express to generate a step voltage to activate a small motor.  I am able to activate the motor, but the duration of the pulse is longer than I want. It lasts for around 500ms and I want it to go for about 25ms.  No matter what I do (ie. make the loop simplier) it still takes about 500ms.  I'm assuming that the computer can output MUCH faster than 500ms, and thus I have a feeling the DAQ express controls the duration of the output..but the trigging options are unavaiable (i.e. they are unclickable).
thank you.
veritas
(2,454 Views)
Express VIs are not suitable for timed DIO.
Take a look at the DAQmx examples.
Esp. Correlated Dig Read with Counter.VI (under Hardware Input and Output\Daqmx\Digital Measurements)
TOn
My LabVIEW Ideas
(2,439 Views)
