USB 6508 Labview example available...or traditional daq example?
using traditional daq vi's
(3,732 Views)
see here.
it is bad form to double post my friend.
Paul
(3,726 Views)
Thanks, this is great!
(appologies about double posting...)
(3,724 Views)
good luck!  I do not mean to flame, but if you are monitoring this forum, you can see how fast new requests are being generated.
Paul
(3,718 Views)
this all works great for outputs.
do you have an example on using the "group read.vi"
at the moment, i use one group config to setup the inputs, and another to setup the outputs. is this the way to do it?
pitty daq assistant does not work for 6508..  😞
thanks
goose
(3,708 Views)
Check to see if you have a \examples\daq\digital folder with a 8255.llb in it. With 8.5, it seems that the traditional DAQ examples are not listed in the example finder but the actual examples are still installed.
(3,703 Views)
Thanks, I found it, but there is no examples on how to use  "group read" vi
I have attached my current VI. Digital out works fine, but Digital in(read) does not.
Also, what is the input named GROUP used for on Group Config.vi ?
(3,704 Views)
