USB-8451 + EEPROM
Hi There,
I trying to replace my standard interface PCB (with MicroChip) with USB-8451 to communicate with EEPROM.
As I'm quite new to this device, may I know which line should I use to connect to the EEPROM & how to write & read from the EEPROM?
Thank you in advance.
Best Regards,
Norman
(3,181 Views)
Hi Norman,
Are you using I2C or SPI to communicate with your EEPROM? The USB-8451 User Guide and Specifications has pin information. See pages 4 and 5 for pin-out descriptions of the USB-8451. I hope this helps!
Missy S.
Project Engineer
RoviSys
(3,163 Views)
