USB-8451 and HMC 5883 Magnetometer
Has anyone used one directly with the 8451 or just with an Ardiuno? Looking for an example to see if it will even work.
(2,686 Views)
You can use this example in the forums to start your project:
HMC 6343 Tilt Compensated Magnetometer
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/HMC-6343-Tilt-Compensated-Magnetometer/m-p/34...
(2,648 Views)
