USB 8451 for I2C
Accepted by Gerardo09
A framing error is generated by the UART on your computer's motherboard. It's typically a hardware issue or a mismatch in serial settings. Search the NI site for framing error and you'll find lots of hits, as this problem comes up often.
Message 11 of 17
(2,678 Views)
Is there any NI modules which contains analog measurements and digital measurements and frequency and also main I2C communication in one module???
Please give a suggesion if any third party modules also including above parameters.
Message 12 of 17
(2,247 Views)
Hi vam,
please stop creating double/multple post for the very same question!
Message 13 of 17
(2,238 Views)
Hello to you all,
I use a usb 8451 to get measurements from a kinetic sensor (mpu 9150) but I have a problem of delaying in displaying and writing data.
I acquire data using ports SDA and SCL of the 8451 device. To make sure that it worked properly I've made a simple experiment.
I attached my sensor to a audio amplifier controlled by my computer. That means that i'me able to send tones to this amplifier, and my vi on labview displays the data on live.
However i observed a delay in displaying and writing the data, and this delay increases during the experiment. This is a graph which shows the evolution of this delay (it exponentionnaly rises)accelero delay.jpg
Do you think that the problem comes from the 8451 device or my labview vi ?
thanks for your answers
Message 14 of 17
(2,153 Views)
Can you give some more information on what this graph is showing? Is that the delay between sending tones to the amplifier and when it is displayed to the front panel and written to your file?
Also, can you post your code here?
Message 15 of 17
(2,144 Views)
It is exactly that. The x-axis shows when we send the tones to the amplifiers (expressed in seconds), and the y-axis shows the delay between the tones and the displaying/writing (also in seconds). I've made another where I send a tone after one hour, and you can gess that I never received any feedback from this system (even after waiting several hours).
This is the code, I'd be very grateful if could take a look at it.
Thank you very much for your help
Message 16 of 17
(2,122 Views)
Nothing in the code stands out to me as a cause for concern. Have you tried using debugging tools to narrow down where in the code the delay is occurring?
Message 17 of 17
(2,101 Views)
