USB-8452: How to address a device with 16-bit register address
Dear All,
I am using an USB-8452 board to write/read registers of a device via I2C.
The device is peculiar, in sense that the register address is not 8-bit but 16-bit.
For example, I want to write 0xAA into register 0x1234 of a device with 7-bit slave address 0x7B (see snippet).
If I use NI-845x VI's I get "Error -301743 occurred at NI-845x I2C Write.vi:4470003" and "NI-845x: The slave did not acknowledge a data byte transmitted by the I2C master."
Is there some way to ignore the NACK?
Thanks for your attention
Message 1 of 1
(2,700 Views)
