USB-8476
I have an NI 8476 USB to serial LIN connector.  After installing the driver which had no issues, I tried to run a Labview executable file which controls a small motor.  I received an error that noted an internal driver error.  The error specified for me to send the attached file to NI Tech Support.  The laptop that I am using is an HP with Windows 7 on it.  I have had no problem running it on another Laptop (a Dell) which also has Windows 7 on it.  Is there a newer driver that will correct this issue? --Thanks!
(4,096 Views)
Hi Jean
Welcome to the forums.
From the file you've included it looks like you're running NI CAN 2.6.2, the helpfile for which I found here.
It specifies that the Windows Vista (32-bit and 64-bit) is the latest release which is officially supported therefore it's behavior on Windows 7 can't be guaranteed.
Please try updating to the latest version of NI CAN from here.
Kind Regards
Chris | Applications Engineer NIUK
(4,071 Views)
Thanks for the reply, Chris.  I updated to the latest version and it gave an internal driver error again.  Same result.  Anything else that I can try?  Thx
(4,029 Views)
Hi jean70,
Go ahead and try the steps in the KB here:
http://digital.ni.com/public.nsf/allkb/25A1726C45E10F48862568F700715733?OpenDocument
Let me know if resetting or running an example program, if you are able to, changes anything. Can you also attach the updated nicanErr.txt after updating the driver?
DylanC
(4,013 Views)
