USB-9211A not recognized
Is the USB-9211A supported under Windows 10?  I have been using one under Windows 7 without a problem, but am trying to use it on a Windows 10 box.  NI Max recognizes the device and correctly identifies it as a 9211A but reports error -88705.  It tells me that the device may not be installed correctly.  I've downloaded the latest DAQ install from the NI web site.  In the past, it was just plug it in and go.
(1,952 Views)
Accepted by topic author Jim12345678
The 9211A needs the NI serial drivers.  The NI serial drivers are not part of the NI-DAQ install.  They have to be installed separately.
(1,947 Views)
