USB Audio Bridge with NI-VISA support
I have a LabView application for a proprietary audio test system based on the Texas Instruments TAS1020B USB Audio Bridge.  I am looking to design a new version of the test system, but the TAS1020B USB Audio Bridge is going end-of-life, and I would like to migrate to another more-readily-available device.
Texas Instruments has provided extensive LabView support for the TAS1020B, but unfortunately, I am not finding an alternative device with a similar level of support.
I need to acquire an audio stream from the USB Audio Bridge, but I also need to do register-level control on the test system.
Does anyone know of a USB Audio Bridge with LabView/NI-VISA support with example code?
(2,764 Views)
I looked up the TAS1020B and saw that they had a recommended replacement, TMS320C5533. Have you looked into that?
National Instruments does not make any product that accomplishes this on an integrated circuit level, so if the suggested replacement doesn't work for you, then I would suggest calling Texas Instruments and seeing what they recommend.
-Lauren
(2,712 Views)
