USB CDC class
I am trying to communicate between PC and uC with usb interface CDC class as a virtual com port. I do have driver for CDC class and after loading it my device is recognised as Virtual Com port in device manager. So as a result I do have a controller which is connected via usb cable to pc and at pc side it is a virtual com port.
 Now as my device is recognised as com port-3 I tried to write labview vi for pc side... I tried to modify basic serial read and write example such that I can continuously send and receive data but I am not able to communicate....My point is that is there something else to do for this case in making vi...or something missing in my vi....
My vi is attached...
(4,449 Views)
Anyone used USB CDC class for communication??
(4,430 Views)
Do you have communication working with Hyperterminal? Before you try writing any code, verify the com settings and cable work with that.
(4,426 Views)
