USB Devices
请问有40通道以上数字DIO,还能USB接口供电的设备有哪些?
(1,519 Views)
Accepted by topic author ArcherLewis
Google Translate:
What are the devices that have more than 40 channels of digital DIO and can also supply power from the USB interface?
The USB-6509 can be bus powered.  You will just likely be limited in the current output of the outputs.  If you find you need more output current, then you can use a 12V power supply.
(1,490 Views)
