USB Joystick
I am trying to find out how to read a USB joystick in labVIEW. I am a
complete novice in this area and have no idea where or how to start.
Has anyone done this?
Phil
(3,874 Views)
Hi Phil,
I responded to your other post. Hope its helpful.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HFORCEKWTID=26604:5&HOID=50650000000800000047400000&HExpertOnly=&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
(3,874 Views)
I don't know if it will help, but there are a couple of joystick examples at http://zone.ni.com/devzone/devzone.nsf/webcategories/E2A99E7E10D5725D862567AC004F0A53?opendocument&node=DZ52048_US. I used one of these a couple of years ago with a non-USB joystick and it worked fine. The one I used worked with any joystick for which there was a driver installed. You might want to give them a try.
(3,874 Views)
I know this is an old post, but this may  still help someone. I've attached code in LabVIEW 2012 that interfaces with a USB joystick using the built-in joystick interface VIs that are included with LV....
Sam Shearman - Sam.Shearman (@) gmail.com
(3,123 Views)
