USB Labview
I would like to communicate with a USB device via Labview. Please, can you give me a exemple of communication (between USB Device and Labview) and how I can install USB devices in MAX(Measurement & Automation eXplorer)
Thanks very
Johan
(3,551 Views)
Check out the following tutorials:
http://zone.ni.com/devzone/conceptd.nsf/webmain/6792BAB18242082786256DD7006B6416?opendocument&node=200065_US
http://zone.ni.com/devzone/conceptd.nsf/webmain/67E175B2AF9AA10286256A9D0078E2E7?opendocument&node=200065_US
Normally it's best to use drivers accompanying the USB equipment but you can also use VISA to communicate directly, that requires that you know the protocol of the unit though.
(3,551 Views)
This is a good starting point. Take a look it may answer this question and others that may come up later.
(3,551 Views)
Hello jojo,
Unfortunately National Instruments do not have LabVIEW examples to communicate via USB.
On the other, you can find below a document explaining you the demarche to be followed:
Sanaa TAZI
Application Engineer
(3,551 Views)
