USB (RAW) - changing Bulk-Out Pipe endpoint gives error 0xBFFF003A
I am trying to interface to a proprietary USB device which communicates via bulk transfers on endpoint 4 for transmissions and 83 for receptions.  I am able to create an .inf file for the device properly and get it to show up in MAX OK.  By default the endpoints come up as 2 for the bulk-out pipe and 81 for the bulk-in pipe.  When I try to change these either in MAX or in a .vi using the USB Raw Bulk Out property node I get error 0xBFFF003A - VISA:  (Hex 0xBFFF003A) Unable to start operation because setup is invalid (due to attributes being set to an inconsistent state). I seem to be able to send out properly on the default endpoint but I get this error any time I try to change to endpoint 4.  Anyone have any ideas as to why I cannot change endpoints through VISA? I can talk to this USB device properly from an embedded USB host application platform so I don't see why I can't through VISA.
Steffan
Message 1 of 11
(6,911 Views)
did u see this.
Message 2 of 11
(6,889 Views)
muks wrote:
did u see this.
This doesn't really help as this refers to serial port configuration. However, the error is probably a general VISA error.  Also, I have another Windows app that can talk to this device over these enpoints just fine so it has nothing to do with a Windows limitation, it is VISA.
Message 3 of 11
(6,878 Views)
 Try using the USB RAW-Bulk.vi provided with the example finder and add the property node to the open session case. I noticed there is no VISA open in the picture you attached as well; you may need to add this.
-Matt
Matt
Message 4 of 11
(6,851 Views)
-Matt
Matt,
Thanks for the reply.  I think the open wasn't necessary since I was using the VISA Test Panel but, in any case, it should have been in there for correctness.  I added it but it did not make a difference.  It give me the same error in VISA Test Panel anyways.  Also, I do not have USB RAW-Bulk.vi in my examples (I am running with 8.0, maybe it was added in later versions).  Could you post it?
Steffan
Message 5 of 11
(6,847 Views)
Hi
I have same problem with my usb device   (error 0xBFFF003A ).
I'm using labview 8.6 with visa 3.4.
Can visa 3.4 be the case?
thanks.
Message 6 of 11
(6,587 Views)
You can try updating VISA.  The most recent version for Windows OS can be found here: http://joule.ni.com/nidu/cds/view/p/id/1605/lang/en.  Were you able to try the example mentioned above?
Message 7 of 11
(6,545 Views)
Hi Matt,
          In the Labview example USB RAW-BULK.vi.After opening the session.How to change the property node??which are the property nodes??I can see only BULK OUT and BULK IN.Iam using a pendrive as my USB device........HelpSmiley Surprised
Thanks as kudos only:)
Message 8 of 11
(5,601 Views)
@danil33 wrote:
Hi Matt,
STOP creating multiple posts for your question!
http://forums.ni.com/t5/LabVIEW/Requirements-to-read-from-a-USB-port/td-p/1959445
You've created something like 8 posts on this same question!!!!
Message 9 of 11
(5,595 Views)
Did anyone come to a solution for this problem? Very similar to the reported problem I can create a NI VISA driver to talk to my USB HDI compliant proprietary device, then using the test panel of the MAX explorer I am able to send commands, but NOT receive them. The problem is apparently the configuration of the IN pipes, which I cannot change in the test panel dialog, receiving the same error message as reported.
thanks all.
Sergi
Message 10 of 11
(5,420 Views)
