USB Relay Borad
Hi all
I am using USB Relay Borad form DENKOVI company , I want to control it using labview
regarding to the company I must use FTDI  D2XX Function for read and write
can any one help me with this
any one use this kind of devcie before ?
thank
(5,188 Views)
According to their website, the USB boards actually mount an on board RS232 converter.
http://www.denkovi.com/productv/66/usb-16-channel-relay-module-rs232-controlled-12v-ver-1.html
At the bottom of the page is some example code for controlling the relays. You can communicate with the RS232 on the relay board with LabVIEW VISA VIs
_____________________________
- Cheers, Ed
(5,181 Views)
Most of the relay boards come with FTDI (virtual COM Port). I know a board that only needs the VCP Driver. After this you can send the commands via VISA on the virtual com port. If you have to use FTD2XX.DLL, create your main vi, include the FTD2XX.DLL via dll node and select the function you want to execute.
You have to define the input and export value for the specific function. You will find them in this document:
http://www.ftdichip.com/Support/Documents/ProgramGuides/D2XX_Programmer%27s_Guide%28FT_000071%29.pdf
(5,175 Views)
